WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
50 CC 232 weights?
Old 09-07-2006 | 07:27 PM
dhooks's Avatar
My Feedback: (24)
Default 50 CC 232 weights?
Been hovering on the edge of pulling the trigger on a new 50cc plane for the last mo or so but need a plane that comes in UNDER 16lbs preferably lighter as I have a cpl 45cc engines that really need a 16lb or lighter plane for acceptable 3D type performance.
Im kinda down to the new Extra or the Cap with my preferance being the Cap if its a sub 16lb plane. Tom has it listed at 8.75lbs which would put me at or under 16 lbs with a decent setup.
My 45s are 6-8oz lighter then most current 50cc stuff so I might even be less then that.
Question is what are you guys coming up with weightwise? Is that a realistic # or are they running heavier then that?
Old 09-07-2006 | 08:39 PM
Default RE: 50 CC 232 weights?
Is the Yak too small an airframe for you? People are saying these are coming in around 15.5lbs with a DA50, and are good 3d platforms. Depending on the 45, this may suffice for you. I'm planning the Yak and MVVS 45. We have a 7kg weight limit in Australia. Anything above it needs an inspection. No big deal, but sufficient to attempt the lower weight.
Good luck.
Old 09-07-2006 | 08:58 PM
dhooks's Avatar
My Feedback: (24)
The Yaks a little small for what I have in mind. A yak at 15lbs has a much higher wingloading then a cap at 16.
Old 09-07-2006 | 08:59 PM
dhooks's Avatar
My Feedback: (24)
Did I mention Im Yakked out also?
Old 09-07-2006 | 09:03 PM
Grotesquebass's Avatar
My Feedback: (16)
i fly the cap with a da-50 plenty of power and harriers so nice didnt get a weight but i am guessing around 16-17 lbs my last one was 16.5 same setup as this one
ID:	520709   Click image for larger version
Old 09-07-2006 | 09:15 PM
dhooks's Avatar
My Feedback: (24)
With an engine 6 oz lighter an losing the wheel pants would drop me down into the high 15s which is where I need to be. This is what I like to hear!
Old 09-07-2006 | 10:23 PM
JoeAirPort's Avatar
My Feedback: (41)
Man that looks nice. I think I need one.
ORIGINAL: Grotesquebass
Old 09-08-2006 | 06:18 PM
dhooks's Avatar
My Feedback: (24)
Or maybe I just need to come off the wallet an get what I want! Something bigger[:@]
Old 09-08-2006 | 08:28 PM
My Feedback: (16)
i am building the 40% as we speak very nice plane
ID:	521202   Click image for larger version
Old 09-08-2006 | 10:27 PM
ben beyer's Avatar
My Feedback: (23)
If you want something in the 50cc class and you're willing to put forth an effort to do a high class set up for the controls, the CAP is the ticket.
Old 09-17-2006 | 09:30 AM
AeroDave's Avatar
Dan,
I have the CAP with a much heavier engine. I have no doubt its what you're looking for, set up light. In fact, I'm thinking seriously about getting a lighter motor for it. I've had mine since early spring and its proven to be a nice model for this size class. It flies great with my G62, but its just too heavy for good 3D performance.
