RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   hard points (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/1221443-hard-points.html)
Diablo-RCU 10-22-2003 07:52 PM
hard points
On the Wild Hare Extra, should the hard points for the ailerons and elevators be drilled at 90 degrees to the center line of the control surface? I read where there is a pilot hole drilled, but I want to make sure of the correct angle.
rctom 10-22-2003 11:23 PM
RE: hard points
ORIGINAL: Diablo-RCU
Yes, that is the correct angle. There are already pilot holes in the hard points, just follow those holes and drill them out to 9/64.
I use a cordless screwdriver instead of a drill, driving a bit with a hex quick-change base. The screwdriver is easier to control and goes nice and slow. It only takes a little bit to drill it to the right size.
Tom Fawcett
