35% Extra
Which wingbags are you guys using on the 35% Extra?
What prop are you running with BME 110? Thanks, |
RE: 35% Extra
I ordered mine from airwild. They fit great.
RE: 35% Extra
Thanks, I was looking at those, but didn't know if they fit.
RE: 35% Extra
ORIGINAL: F1race79 What prop are you running with BME 110? Getting back to your original question, if your engine is new, a Menz 27x10 is a good prop for break in. By the time you've got three gallons through it, you'll want to move to a 28 inch prop like the Mejlik 28x10 which offers excellent thrust and vertical performance. After 2 or 3 more gallons, my 110 continued to break in and make more power, and soon was ripping that prop like crazy. I went to the excellent Air Wild NX 28x10 that provided more load, excellent thrust, and better downline braking than the Mejlik, while being quieter than the Mejlik. Several gallons later, the BME continued to get stronger and now the NX28x10 was howling like a banshee. My prop of choice now is the Biela 28x10, which is very quiet, pulls like a bear, and has the best downline braking of any other prop I've tried. The main thing is that the Bemmer likes props that load it in the 6100 to 6600 range with 6400 to 6500 being optimum. Keep the airflow adequate and keep the mixture correct (no lean running) and use petroleum oils for 6 or 7 gallons before switching to synthetic, and you'll see the same performance increases as the engine "comes in". The 110 is a HARD runner with stock mufflers, but the Pefa LLs are worth 200 to 300 rpm more than stock mufflers, which, on a 28 inch prop is POUNDS of additional thrust. Combine that with the fact that the engine is quieter, AND the cannisters help with balance so no "dead" weight is needed, the Pefas offer the best combo if you can swing it. I can post pics of my cannister install if you're interested. |
RE: 35% Extra
I just looked back and found a previous post of mine that had pics of my cannister install. It's at http://www.rcuniverse.com/forum/m_21...y_wing/tm.htm#
RE: 35% Extra
Thanks for the info and pics.
I almost got the Carbon Fiber cannisters for mine, but it was going to run about $600. I will look into the Pefa LL cannisters. Thanks, |
RE: 35% Extra
Did you guys know that we make a canister and mount for this plane now? Mufflers are 2 1/2" x 10", they are $100 each. The mount costs $15.
TF |
RE: 35% Extra
That's good to know Tom, thanks.
I will give you a call when I go with cannisters. Where are you getting your dashboards for the Extra, since you have to have one for IMAC. Thanks, |
RE: 35% Extra
Tom sells the dash as well. One stop shopping.
RE: 35% Extra
OK, almost finished with my Extra with BME 110.
Do any of you guys baffle for the BME 110? Thanks, |
RE: 35% Extra
Because of the positioning of the cowl openings generally baffling is not required.
TF |
RE: 35% Extra
Thanks, Tom.
One more question. What are the colors on the 35%? Thanks, |
RE: 35% Extra
True red, cub yellow, midnight blue, white.
RE: 35% Extra
Thanks again Tom.
RE: 35% Extra
Julius, I don't have baffles on my BME 110/WH 330 either, Dean
| All times are GMT -8. The time now is 05:11 AM. |
