RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   Extra Special setup (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/2862812-extra-special-setup.html)
trroscoe 04-10-2005 03:23 PM
Extra Special setup
I am almost ready to maiden my extra special and would like some advise on what to set the throws and expo's at. I am planning to use this plane for basic and sportsman IMAC style flying. I may try some 3D after some practice with my other plane first. I have it setup with the recommended throws in the instruction manual but would like to know what everyone else is using. I am thinking about setting them up on one of the three position switches. I have a futaba 9C radio so have all of the mixing options available. I am also curious to know what percentages you guys are using to set up your snap roll function. Also what is the best percentage difference for aileron differential. Any radio help in setting up the mixes for this plane would be a great help.
Rick
flatlandmike 04-10-2005 06:13 PM
RE: Extra Special setup
i set my elevators to 12° aka 1 inch and my ailerons to 7/8 inch rudder i don't know ?
thats low rate for imac and for middle rate enough elevator for a square loop and enough aileron for rolling 1 role per sec and enough rudder for a nice knife edge loop for imac and high rate full deflection because i like to do crazy things with my plane :D
thats how my WH extra special is set up i need many flights to get the dialed in and I'm sure some of the rate will get tweaked
