RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   HInges (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/2899465-hinges.html)
Julien Hp 04-21-2005 04:34 PM
HInges
Hi guys !
I glue the hinges and Yesterday, I saw taht one of them where not glued ( right wing) anyone know how i could glue it ?!?!
thx Julien
Easy does it 04-21-2005 08:19 PM
RE: HInges
Which one is it and what plane is it?
Julien Hp 04-21-2005 09:03 PM
RE: HInges
It'S the Edge 540t and Its robart hinges...the 3 one when counting from the fuselage...
julien
mstroh3961 04-21-2005 11:04 PM
RE: HInges
You should get a syringe and fill it with poly glue. Deflect the surface and slide the needle beside the hinge point tell you pass the barbs. dispense the glue as you slowly withdraw the needle. do this on both sides of the hinge, above and below as well. The poly/gorilla glue foams as it cures so it should fill in around the barbs.
Good luck!:D
mstroh3961 04-23-2005 10:52 PM
RE: HInges
Julien, How did you make out?
playntalkr 04-24-2005 01:32 AM
RE: HInges
I think you need to wet the glue with water to activate it.
Skip
Julien Hp 04-24-2005 08:02 AM
RE: HInges
I will take a syringe and fill the hinge hole with pro-bond polyurethane....
Thank you Julien
3dd 04-24-2005 10:31 AM
RE: HInges
you don't HAVE TO USE WATER to foam the glue but it helps in certain jobs
