RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   Pull/Pull Extra 300SP (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/2956681-pull-pull-extra-300sp.html)
kevleboeuf 05-08-2005 09:53 PM
Having a little trouble with the pull/pull on my Extra 300 Special. I`m using a single JR8611 in the slot closest to the tail with a 3.00" servo arm. The pivot for the servo is also closer to the tail. With the horns on the rudder 3.00" apart, on the hinge line and the cables straight ahead, they rubb on the fuse and a former just inside the fuse slot by quite alot. So I crossed the cables at the servo and now they only rubb on the fuse . What can I do to solve this or is this exceptable? And how much slack should it have on the opposite side when turned 45% ? Thanks Kevin
rctom 05-08-2005 11:55 PM
RE: Pull/Pull Extra 300SP
It's better if they don't rub but really no big deal as long as they stay taut. Run then straight, if you feel the need trim that formet where they rub, or if crossed a little slack in the non-pulling wire hurts nothing.
TF
Tired Old Man 05-09-2005 03:20 PM
On my planes I just extended the slot a little with no ill effects.
