RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   Extra260 Ign Switch (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/4560685-extra260-ign-switch.html)
japan3d 07-29-2006 10:25 PM
Extra260 Ign Switch
Just about finished with the Extra 260, and ran across a small problem. I installed the MPI switch in the right hand location already cut out for you at the factory. Now how do I run the wires to the battery and ignition kill switch? Drill 1/2 holes in the engine box plywood that runs back to the wing tube? Or use extensions and run it out the holes already cut in the plywood?
mstroh3961 07-30-2006 01:35 AM
RE: Extra260 Ign Switch
I would use extentiions.
japan3d 07-30-2006 05:04 AM
I got it all figured out. Just need to mount the canopy now and shes ready for her maiden.
