260 33%
Tom what are the incidence's on the plane MOTOR, STAB, WING.
RE: 260 33%
0-0-0
RE: 260 33%
Dennis
Did you pic up a WH 260? There is a guy at out field in Sherman that loves his. Shaun |
RE: 260 33%
Shaun. Yes i just did the maiden on it saturday and had a problem with the plane balloning when i cut the throttle. When i got home last night i checked the thrust angel on the motor and i have 1 deg of down.
RE: 260 33%
That will do it. With power on you will be using some up elevator to counteract the down thrust. When you cut the throttle theplane then sails upwards.
TF |
RE: 260 33%
ORIGINAL: rctom That will do it. With power on you will be using some up elevator to counteract the down thrust. When you cut the throttle theplane then sails upwards. TF |
RE: 260 33%
I would practice landing or maybe fly more. Mine will not ballon when landing and you built it. Thanks maybe get rid of your JR radio or you probly have to much expo on your elevator
RE: 260 33%
ORIGINAL: bladebender I would practice landing or maybe fly more. Mine will not ballon when landing and you built it. Thanks maybe get rid of your JR radio or you probly have to much expo on your elevator |
RE: 260 33%
Dennis,
Have you double checked your CG? I'm sure you know that a tail-heavy plane tends to baloon on landing. I know I've had that problem with more than one plane. |
RE: 260 33%
ORIGINAL: Aerohead Dennis, Have you double checked your CG? I'm sure you know that a tail-heavy plane tends to baloon on landing. I know I've had that problem with more than one plane. Yea i did that already...it's still a tad nose heavy. im sure it's in my standoff's |
