33% edge bme115
is this a good combo thanks?
RE: 33% edge bme115
It should be awesome. Light engine, light plane, lots of power, what more can you ask?
TF |
RE: 33% edge bme115
Massive power overkill, but since it's so light you probably couldn't get a smaller engine to do the job that's any lighter. That's the sweetest thing about the 115, it covers so many different power requirements and still weighs less than anything else that would work. All you have to watch is the throttle position and the prop's ground clearance.
RE: 33% edge bme115
I have the 260 with the 115, while it is overkill on power, its just right for me. I am using the graphtech carbon gear and have plenty of ground clearance for anything up to a 30" prop. Its a good combo, a little hot rod with near foamy power to weight.
RE: 33% edge bme115
BUT YOU LIKE SLOWWWWWWW THING :D:D:D:D
| All times are GMT -8. The time now is 08:33 AM. |
