CG on Extra 300 50cc version 2
Hello
I going to mount my batteries and wounder where you have your cg? Is 3 and 1/2 from the leading edge with the wingrot ok? Best regards Daniel in Sweden |
RE: CG on Extra 300 50cc version 2
Balance it on the center of the wing tube. Pull a string from tip to tip parallel to and centered on the wing tube, mark wher the string hits the tips. Pick it up by the tips at the mark.
TF |
Thanks for quick answer. I sit here on the other side of the planet with a glass of wine and lock on the Extra!
I have a DA 85 that wait on your 35 Extra or Edge when it come to Europe! I try to hang it on steelwire around the wingtube, it shouldnt tip back or forward if th cg its ok! |
Is that with full half or emty tank?
Empty.
1 Attachment(s)
ORIGINAL: danielwidman79 Thanks for quick answer. I sit here on the other side of the planet with a glass of wine and lock on the Extra! I have a DA 85 that wait on your 35 Extra or Edge when it come to Europe! I try to hang it on steelwire around the wingtube, it shouldnt tip back or forward if th cg its ok! Daniel, I think the best, easiest way to determine/set your CG is to use the " Vanessa CG Machine". They are a snap to make and work great. Check this site. http://home.mindspring.com/~the-plumber/ Vanessa %20CG%20Machine.htm Don't let the instructions scare you. There really is nothing to it. Be sure you use a small level so you you get the plane horizontal (level). Here are a couple of pics of one of my planes suspended on the Vanessa . You can't see it, but I put a small mark on the fuselage where the GC is supposed to be. When the plane is level, the plumb bob points to the GC. Just move around some weight (probably batteries) to get the plumb bob pointing at your mark. That's all there is to it. Nice thing about this method is that you immediately see the results of moving the batteries around. After you move them just re-level the plane by twisting the dowel in the appropriate direction and you can see what effect the move had. Good luck |
Tom,
Does the first version ALSO balance ON the wing tube ?? I have a one or two flight version ONE that I purchased used.. Updating most everything on the plane... Walt.. |
ORIGINAL: Walt and Sage Tom, Does the first version ALSO balance ON the wing tube ?? I have a one or two flight version ONE that I purchased used.. Updating most everything on the plane... Walt.. |
Tom,
The version 1 manual says "3 1/2" to 4 " behind the leading edge at the wing tip". Does that correspond to the wing tube location??? Thanx |
ORIGINAL: Rfabbre Tom, The version 1 manual says "3 1/2" to 4 " behind the leading edge at the wing tip". Does that correspond to the wing tube location??? Thanx TF |
| All times are GMT -8. The time now is 08:21 AM. |
