RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   540T V1 root CG location (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/7838397-540t-v1-root-cg-location.html)
dmparri 08-12-2008 04:47 PM
Have a 28% 540T V1 looking for a wing root CG location I have a precision balancer for large planes and find the tip measurements given in the instructions OK but would like balance dimensions at the root location instead of fingers out on the tips of the wings
Thank you
skyriter 08-12-2008 06:02 PM
RE: 540T V1 root CG location
Think the Edge 540 has a straight leading edge, so it will be the same. For planes with tapered leading edges, assemble the wing on the pipe out of the plane, then mark the CG on the tips, stretch a string between the tips and mark the CG on the wing root and you have the info required.
Bruce
