Wren 44
Wren 44
hello
does somebody have the baiscs parameters of the ECU for a "old" wrem MW44 green?
today icould not run mine and having those üarameters iu can check with mine..
just to describe my problem:
starting as good as always, then going from idle to full, even with slow stick movement i got flames out..
so tomorrow i will try to find out where the problem is, if is the pump, the kero or some others parameters..
i'm reading trough the forum, but i could not ind those ECU parameters..
thanks for the help
alessio
thanks for the help
alessio
RE: Wren 44
Hi Alessio,
I had the same problem so check this first, the easiest check.
Make sure you have not lost any screws from the rear of the engine, both those that hold the nozzle on
& the ones that seat through the larger holes in the nozzle.
I run a 4.8 volt nicad pack to the ecu for this engine.
Full power speed 190k
Idle speed 57 k
stop speed 35 K
start min temp 100 degC
Max temp 800 degC
Acc delay 021
Decel delay 020
Stability delay 040
Pump start point auto + 1
Pump ramp start 014
My other engine has a 3.6 volt nicad pack, the difference in voltage may affect the settings.
- John.
Idle speed 57 k
stop speed 35 K
Max temp 800 degC
Acc delay 021
Decel delay 020
Stability delay 040
Pump ramp start 014
- John.
RE: Wren 44
Hey John
thanks for the help...
but i did solve my problem 50/50..
after reading your settings, i did run my wren 44 without problems.
yesterday on the flying field, the problem did reappear!
starting was smooth
idle was ok, but as soon i moved the stick to accelerate, the engine quit..
now is troubleshooting..
or is a problem in the pump
or in the ECU
no idea...
starting was smooth
or in the ECU
no idea...
My Feedback: (39)
RE: Wren 44
Alessio,
The listed parameters, with the exception of the accel and decell...are for startup.
When the motor quits...does it smoke??
Easiest diagnosis would be air bubbles in the system.
Worst case would be pump or ECU...probably pump.
rb
rb
RE: Wren 44
thanks Ron
i'm betting the same
no air bubbles can be seen by me and my helper..
the pump is not somehow working properly..
no smoke when shutting down
or the ECU output is Screwed...
i have a spare pup that i will test
alessio
alessio
RE: Wren 44
ORIGINAL: Boomerang1
Hi Alessio,
Idle speed 57 k
stop speed 35 K
Max temp 800 degC
Acc delay 021
Decel delay 020
Stability delay 040
Pump ramp start 014
- John.
Hi Alessio,
Idle speed 57 k
stop speed 35 K
Max temp 800 degC
Acc delay 021
Decel delay 020
Stability delay 040
Pump ramp start 014
- John.
RE: Wren 44
Hi Joe, the figures may be different because the early 'Green' engines were manual start. Your 'Gold' engine is full auto start.
The manual engine ECU is different as the manual start engines have no solenoids to power up, no glow plug to energise & no starter to engage.
All the ECU does on the manual start engines is monitor the RPM & exhaust gas temp & start & run the pump.
With just a small motor on the pump to run they use a smaller, lighter battery, either a 3.6 volt 500 mAh 3 cell nicad or a 4.8 volt 4 cell. I don't know what brand pumps these engines use, as far as I know they are Wren items, all machined from aluminium with two small allen head screws with pink thread locking compound holding them together. John.
