Modernizing a Wren 54 Mk2?
FL
I have an old Wren 54 Mk2 which I would like use and bring forth into the the world of modern turbines. I know that mechanically I cannot do much, but can the computer controls be updated by using a new FADEC control and reprogram it so that it behaves much like a gas autostart turbine?
My Feedback: (39)
If the motor has a starter attached, you can purchase a Xicoy V-10 ECU and upgrade it to an auto start. You will need two solenoids though. I can program the ECU for you but some adjusting and fiddling can be expected!
Hope this helps.
Hope this helps.
My Feedback: (39)
Our ECU program is suited more for the latest designs. Your pump, combustion chamber, diffuser...ect are of an earlier vintage...making the default settings a bit different than what you may require. It's very possible to do...just takes some patience.
Ron
Ron
