Help with Wren MW54
Help with Wren MW54
Hey guys ,
I`m building a wren mw54 and I had a manufacturing problems with the vaned diffuser because there is no available "CNC" machines nearby in the city and it needs a pretty good accuracy since the vanes are 0.8 mm tickness.
I found that the wedged diffuser is also used for the engine and it`s easier to be manufactured. but actually I don`t have its drawings , so if any one has it and he could send it to me I would be so grateful.
now I have 2 Questions :
1) Is it good to be used for the engine ?
2) Can I use the vaned diffuser and increase the thickness up to 2mm fo example ?
Thank you.
Thank you.
