Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > Wren Turbines USA
Reload this Page >
replacement fuel mainfold
Wren Turbines USA Wren USA no longer providing support for their turbines. We are converting this forum into a member supported support forum. This means members will solve members problems
Old 01-19-2010, 11:44 PM
seflyer
My Feedback: (12)
Default replacement fuel mainfold
I am in need of a replacement fuel mainfold, it is a mark 1 kit built turbine and has a damaged needle that is leaking. could make do with replacement needles.
any info on replacement parts would be great, thanks Kevin
Old 01-20-2010, 06:49 AM
Wren Turbines USA
My Feedback: (39)
Default RE: replacement fuel mainfold
Kevin,
I have some unusable rings that you could salvage a needle from..pm me your mailing info and I'll send you one.
Ron
Old 01-20-2010, 10:42 AM
seflyer
My Feedback: (12)
thanks Ron, I'll give the silver soldering a go.
PM sent.
Kevin
Old 01-20-2010, 08:43 PM
jefff
My Feedback: (8)
Kevin,
You could also use .5mm Hypodermic needles ( 25G ). This is the size that was first used in the Homebuilt MW54. I had a hard time keeping them from pluging. I went to .6mm Hypodermic needles (23G1) and had no problem. But you have to keep them all the same. Mike the diameter of the needle to see what size is in your fuel ring.
Jeff
Old 01-23-2010, 09:56 PM
seflyer
My Feedback: (12)
Ron, manifold arrived today, first class service there. the ring you sent me looks to be in better conditon than the one that was installed, I will do the light test tomorrow and see how they burn, if all even, I will just swap out the feed line that is damaged, I think this would be easier than trying to solder one of the needles anyway.
my thanks Kevin
Old 01-24-2010, 05:38 AM
Wren Turbines USA
My Feedback: (39)
Kevin,
Best way to splice is to use a brass pipe with larger ID and splice the 2 pipes in the middle. Assemble the chamber on to the diffuser and then make the solder joint.
Good luck,
Ron
Old 01-28-2010, 12:26 AM
seflyer
My Feedback: (12)
after some considerable effort, I have 9 of twelve sticks burning ok. is it possible to just get a replacement manifold? the unusable on you sent me fits perfect, just have not been able to get all the sticks burning, these are some seriously small tubes.
Kevin
Old 01-28-2010, 07:10 AM
Wren Turbines USA
My Feedback: (39)
I have new ones on the shelf. I'll get one out to you!
Ron
Old 01-28-2010, 10:46 PM
seflyer
My Feedback: (12)
thanks, I will call the shop tomorrow for payment.
Kevin
Old 02-02-2010, 08:50 PM
Xairflyer
Xairflyer's Avatar
I used a strand of wire from a control cable (bowden cable) in the needle if you find by measuring, it goes in the full way, and still seems blocked, try squeezing the fuel ring at the bottom of the needle so it ovals it slightly and so giving more clearance to the bottom of the needle.
Worked for me.
