Go Back  RCU Forums > RC Helicopters > XHeli.com Support Forum
 Building my first heli EXI 450 Pro, need some advises. >
XHeli.com Support Forum If you have a question, problem or concern about your product from xheli.com, please use this forum to get answers to your questions.
Old 07-04-2011, 03:58 PM
Default Building my first heli EXI 450 Pro, need some advises.
Ok guys Im building my first heli. Its a exi 450 pro. I do have a question. When I am setting up the swash plate, Should I set the servos so that, on low throttle I have negative pitch and at mid throttle zero pitch and over half throttle positive pitch. I really appreciate any input on this matter.
Or since I am a beginner should I just go ahead and set zero pitch at low throttle and as the throttle goes up pitch goes up I was thinking this way I dont need too much of head speed to lift off or am I wrong on this one?. I dont even know how to fly it yet so I dont think I will use a negative pitch for up side down flight. ( that is what the negative pitch is used for right?)
Old 07-05-2011, 10:49 AM
Snowboard_Nut's Avatar
Default RE: Building my first heli EXI 450 Pro, need some advises.
I'm a newb too, so anyone feel free to elaborate on what i'm about to say because I am about to encounter my first setup too and at this point have been thinking about this very thing in my head. It is my understanding that the transmitter will have throttle and pitch curves and it will need to be set for 0 pitch for spool-up, which is low to mid-stick, then anything from mid-stick and up will maintain the same head speed, but the pitch will increase. And as your skills progress, you will find that once you are in any position higher then mid-stick, you will be able to flip your IdleUp switch which will then keep your headspeed the same irregardless of your throttle stick and at that time anything below mid-stick will produce negative pitch, and anything above mid-stick will produce positive pitch. That is what I have come to understand, I have never personally witnessed a setup in person, but this is what i've observed from hours and hours of reading forums and watching Youtube. Hope this helps....
Old 07-05-2011, 11:01 AM
Here are the website that show you how to setup the helicopter from ground up www.helifreak.com and look for bob white video.
Eric</p>
Old 08-02-2011, 07:04 PM
on normal settings at 50% throttle most go with 0 - +1 pitch  then like on mike i believe its -3  low throttle and + 10 full  make sure you loctite every screw and watch it because they are cheap chinese metals they will strip and break
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
