YS Engines Support Direct support from YS Performance Engines by Dave Shadel
ys63 fuel consumpsion
Old 01-29-2014, 03:53 AM
Default ys63 fuel consumpsion
I am trying to mount my ys63s in a funtana 40S and I can't put too big a fuel tank in it.
Probuild said a 63 would use 1/2oz. per min. , but did not say if that was full throttle or less some times.
I don't have a their site name to go to them. If anyone has contact info for Probuild I would like to contact them.
I think I can get a 8 oz. tank in, have not tried it. If I can get a little better than 1/2 oz. per min. not running full out I will try a 8 oz. tank.
sticks
Old 01-30-2014, 08:49 AM
never mind, don't really need help on this anyway!
I will just go with the 1/2 oz per min.
I am putting in a 12 oz. tank, its tight and I will have to cut some supporting members to get it in.
sticks
Old 01-31-2014, 10:43 PM
autoguns's Avatar
With the CG in mind you may want to move the tank aft into the radio bay , with the YS pressurized fuel system it's not a problem and with the CG moved back you'll find the funtana 3ds better
Old 02-01-2014, 01:30 PM
thanks for the help. Had not though of putting it back. Not used to a engine with that much pressure.
sticks
Old 02-02-2014, 03:43 AM
went and looked at the idea of moving the tank back, it would have to be behind the wing toward the tail. The wing fills that area, I can shoe horn it in the front.
sticks
Old 02-02-2014, 04:35 PM
autoguns's Avatar
If possible try to keep it to the center of the wing Where the CG line of the plans show
Old 02-04-2014, 08:44 AM
can't really do that as the wing fits into the fuse and does not leave room. I have it in the nose , had to cut a little and reinforce.
thanks
sticks
Old 02-15-2014, 06:19 PM
I have been trying several combinations of tanks in a H9 twist 60 and although it is not a YS 63 my 115 fz will run for 6 + minutes on a 9.1 oz tank. I will bet your 63 is pretty good on fuel.
Old 02-18-2014, 04:05 PM
I was told 1/2 oz per min. I am putting a 12 oz. tank in it. Should be good I generally fly about 12 to 15 min max . I like to have some extra time, in case some one is dead stick or something.
loren
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
