YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 115 flkooding
Old 04-19-2016, 11:03 AM
Default YS 115 flkooding
My YS 115 sport engine floods when I try to accelerate from idle.
Dies and fuel runs out the carb.
Adjusting doesn't help.
Have never had the fuel regultor apart on this new design.
Does it use the same silicon diaphragm the older ones use?
Old 05-18-2016, 06:24 AM
My Feedback: (29)
speedracerntrixie's Avatar
Yes it does use a silicon diaphragm. What appears to have happened is the regulator is stuck in the open position and needs to be flushed. Remove the regulator from the engine, remove the two cover screws and regulator. Hook up your fuel pump and while very carefully holding the lever down, pump fuel through the regulator. I like to do this with an electric pump otherwise you will need a helper and I also like to do this either over a jar or white towel so I can see if I flushed any debris out. Unfortunately this is about the only maintenance that can be done with the new regulator that I am aware of and if that doesn't work after a couple tries you may have to replace it. Not that I have had many issues with this new regulator but I have gone to carrying a spare. Been sitting in my flight box for over a year now.
Old 05-18-2016, 07:16 AM
Default YS 115 flooding
Thanks for the reply,
have tried blowing air thru it, will try the fuel pump method, that may work better.
Old 06-12-2016, 07:48 AM
Turns out, the factory initial setting of two turns out, is way too rich.
Talked to Rich verano, he said turn it way out, half turn at a time.
Turned it out to almost flush with the housing and it runs good.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
