YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS110 FZ Front Bearing Oil Seal
Old 07-01-2007, 07:38 AM
MustangAce
MustangAce's Avatar
Default YS110 FZ Front Bearing Oil Seal
Is the Front bearing oil seal installed with the "cup" or "u" side facing the rear of the engine or towards the propeller??
Old 07-01-2007, 11:23 AM
Troy Newman
Default RE: YS110 FZ Front Bearing Oil Seal
The cup faces toward the engine...away from the Prop
As internal pressure in the engine builds up the cup will flare out and seal....if you install it with the cup facing the prop its going to leak.
Troy Newman
Team YS
