YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS FZ 110 Prop Nut Thread Size
Old 07-24-2007, 12:28 AM
sdcranford
Default YS FZ 110 Prop Nut Thread Size
What is the thread size for the prop nut on a FZ110?
Thank you in advance for the answer...I have checked all over and can not find an answer.
Old 07-24-2007, 06:39 AM
Kaos Rulz
Default RE: YS FZ 110 Prop Nut Thread Size
You'll find that to be a 24x5/16
Old 07-24-2007, 07:39 AM
sdcranford
Thank you!
Old 07-24-2007, 01:13 PM
Kaos Rulz
Actually I had it reversed, but I think you understood it as 5/16" shaft with 24 threads/inch.
Old 07-24-2007, 04:56 PM
baller22
baller22's Avatar
Since YS engines are manufactured in Japan all the threads are metric (fortunately...)
The prop nut thread size is actually 8x1mm
Al
Old 07-24-2007, 09:29 PM
Jimmy Skids
Jimmy Skids's Avatar
8x1 is the correct answer.
Jimmy Skids
Old 07-25-2007, 06:35 AM
Kaos Rulz
Interesting! I just used a prop nut off my FZ 110 to seat a ST 75's prop and the ST 75 is a 5/16 x 24 (also made in China, albiet formerly made in Italy)
There's a possibility that I may have mislabeled the nut. I'll check it out when I get home tonight.
sdcranford - ya might want to wait and verify this with Troy when hew returns. I'd hate to cause any grief with bad info.
Old 07-25-2007, 08:30 AM
PJ_TankPilot
PJ_TankPilot's Avatar
All YS four stroke engines from the .63 up have crankshaft threads 8mm x 1mm.
This is very handy. All my prop and spinner mounting hardware works on all my YS engines.
Old 07-25-2007, 10:01 PM
Troy Newman
8mm x 1 is correct.
Troy Newman
Team YS
Old 08-13-2007, 03:07 PM
areharrt
The reason that your 8mmx1mm fit the 5/16-24 is that the thread pitch of 1mm vs 24 is very close and for about 1/8" there is not enough difference to cause binding. If you try to thread on something threaded deeper, say a alum spinner nut, you would find that a 5/16-24 spinner will go about 2 1/2 turns on the 8mmx1mm shaft before you would get binding (cross thread). Don't ask me how I know this
