YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 45 not picking up fuel
Old 11-02-2007, 10:54 PM
jdp8488
Default YS 45 not picking up fuel
i believe everything is clear up undtil the fuel goes from the regulator into the carb. i took the reg diaphram part off and soaked it in alcohol along with the carb. still no luck. is there any tips or tricks on how to clear the engine of any debri that might be stuck somewhere in the engine?
Old 11-02-2007, 11:54 PM
Troy Newman
Default RE: YS 45 not picking up fuel
The key is to disassemble the parts and use a a fuel pump to pump fuel through the little ports. Just hook up the fuel line like you are filling your tank, and flush out the little hole and ports.
This will require you removing the regulator assembly and flush it out. This is the part that sits below the carb. Flush this out with raw fuel and you should be all set.
Troy Newman
Team YS
Old 11-03-2007, 09:20 PM
jdp8488
thank u sir. sounds simple enough.
Old 11-05-2007, 12:42 PM
eenei
i can suggest to pick a really thin wire and past it thru the little holes and put a new gaskets, make sure the bolts are tigth equal before starting the engine.
Good luck.
