YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS63fz vibration
Old 11-24-2007, 06:16 PM
lennyk
My Feedback: (12)
Default YS63fz vibration
I have found that my 63fz vibrates a lot more compared to a 53.
Both are mounted on similar profile airplanes and the 63 causes the ailerons to bounce/vibrate at idle.
Is this expected or should it be close to the 53 in vibration ?
Old 11-24-2007, 06:32 PM
Troy Newman
Default RE: YS63fz vibration
Lots of things can affect vibration levels...Prop balanced, motor mounts will affect it, and even if its been crashed and maybe the crank is bent.
Troy Newman
Team YS
Old 11-24-2007, 10:15 PM
lennyk
My Feedback: (12)
just checked the crank with a dial gauge and it is indeed slightly/barely bent
only contact this engine ever had was a prop strike a while back in another airplane
I guess the profile fuse doesnt dampen vibrations very well.
apart from a new crankshaft and bearings will anything else be required ?
I've taken apart and changed bearings in a 53 before, anything special with regards to this 63 engine ?
Old 11-24-2007, 11:08 PM
Troy Newman
Nothing special with the 63....But bent at all will affect the vibes....
Sometimes it takes that magically perfectly located hit to bend it.
New bearings and a crank will do you up well.
Troy
