YS Engines Support Direct support from YS Performance Engines by Dave Shadel
They are different the YS 110 and 110S
Old 05-12-2008, 01:51 PM
Guillermito
Default They are different the YS 110 and 110S
Hello, washers that used in the earlier version of the YS 110, I did not serve in the new 110S. I think that both engines were equal.
Thank you.
Old 05-12-2008, 02:31 PM
Troy Newman
Default RE: They are different the YS 110 and 110S
I don't understand the question.
Troy Newman
Team YS
Old 05-12-2008, 07:44 PM
Iflyglow
My Feedback: (79)
Iflyglow's Avatar
Troy,
He could be talking about the drive washer which is a little different. Also the mounting bolt area on the engine lugs is much tighter to the crankcase on the S than FZ. Std 8-32 flat washers would not fit on my 1.10S, since the crankcase is thicker were the mounting bolts are located. I filed flats on one side of the washers so they did not rub the pretty crankcase.
Old 05-12-2008, 09:24 PM
Troy Newman
Guillermito,
Please post a photo of what you problem involves
Troy Newman
