YS Engines Support Direct support from YS Performance Engines by Dave Shadel
New YS170DZ Qs?
Old 05-17-2008, 09:08 AM
Aresti-RCU
Default New YS170DZ Qs?
Troy,
I just received my new 170DZ and I have a couple of questions:
It feels "draggy" to turn, both the crankshaft and the carb butterfly valve. Could this be caused by thick machine oil used to store the engine?
Should I break in the engine in the bench or can I do it in the plane?
What is the break in procedure? rich mid throttle run for a couple of tanks would do it?
Thanks in advance
Old 05-19-2008, 04:47 PM
Troy Newman
Default RE: New YS170DZ Qs?
The way I break the engines in is run them at 4000rpm for about 5mins time then let it cool completely before starting it again. I never hit full power or really adjust mixture settings other than if it is obviously lean...I never go to full power until the engine has 3-4 of these 5min runs at max rpm of 4000rpm.
The keys are to keep the engine from getting HOT and to only run short bursts of about 5mins at a low rpm until the parts break in. Then after I do this for 3-4 runs I will peak the HS and back it off about 300 rpm and this is where I fly the engine.
The slight drag that you describe might be normal. I can't say without touching your engine. I would suspect it is fine out of the box.
Troy Newman
Team YS
