RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   YS 61FR Needle assembly & Shadel AAR setup (https://www.rcuniverse.com/forum/ys-engines-support-197/1283519-ys-61fr-needle-assembly-shadel-aar-setup.html)
oisf3a 11-17-2003 06:41 AM
Hi Dave
The needle valve assembly on my old YS61 is broken and spare parts not easily available.
If I remember right I have a spare needle assembly for my YS140's (somewhere...) and also think the threads are the same as with the 61....
Will this needle assy work with the 61 or is the O-ring spacing and holes different from the original 61 assy ?
From what I remember the 61 needle looked similiar to the first YS120FS needle assemblies and on the 120FS the
140 assemblies could be used.
Am i right ?
Another question that probably only Dave can answer :
This engine has the Shadel AAC piston/liner with an arched exhaust port. Haven't used it for ten years and it only flew for 20-30 flights with this setup before it was replaced by the 120AC.. I do rememeber the engine to be more powerful and less temperamental with this setup than original.
The question is : Is this setup ported for higher or lower rpms than the original setup ? Pipe considerations ?
I think I ran the engine at about 9500-10000 rpms on the ground using Asano 12.5-11 or something like that with the original setup.
Thanks..
Oistein, Norway
Dave Shadel 11-17-2003 12:41 PM
RE: YS 61FR Needle assembly & Shadel AAR setup
We still have the NV assemblies. E-mail your order to [email protected].
I used to run the P/C like you have at about 10500 to 11000 for best results.
Nice to hear from you!
Dave
coloradoz 11-17-2003 01:08 PM
Would this work for a YS 60 too?
...AJS
[email protected]
Dave Shadel 11-17-2003 08:50 PM
Not for the 60, sorry.
