RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   Step-by-step YS 63 setup (https://www.rcuniverse.com/forum/ys-engines-support-197/1334958-step-step-ys-63-setup.html)
Aero104 12-07-2003 09:01 PM
Is there a step-by-step procedure for setting valve clearance, high speed mixture, idle mixture, and pump pressure on the YS 63 ?
Thanks, Chris.
Dave Shadel 12-08-2003 12:01 AM
RE: Step-by-step YS 63 setup
Not for valve clearance. Pull the plug, put it at TDC, and adjust the valves to .003". For running instructions see www.ysperformance.com
