RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   SF120 performance (https://www.rcuniverse.com/forum/ys-engines-support-197/1674910-sf120-performance.html)
DHammer 03-30-2004 07:21 PM
SF120 performance
Hello Dave, quick question. I have a SF120, sweetest running engine in my fleet. I did have it in a plane that weighed 8 1/2 lbs. Was swinging a 16X8 at 9200. Gave me unlimited performance on the plane. It's been idle for a year and now I want to put it in a plane that weighs in about 9 3/4 lbs. Is the 9 3/4 lb plane too much for this engine swinging the same size prop?
Dhammer
Dave Shadel 03-31-2004 09:19 AM
RE: SF120 performance
Depends on what type and how much wing loading. A Cub at that weight vs. a pattern airplane at that weight will be two totally different animals.
DHammer 03-31-2004 08:33 PM
Good point. Fun fly 3D type with a wing loading right about 16OZ per Sq Ft.
Dave Shadel 04-01-2004 11:02 AM
I'd say it will work fine. You may have to go with a larger diameter, lower pitched prop. Be ready to experiment.
DHammer 04-01-2004 07:46 PM
Thanks Dave, Will do.
Dhammer
Dave Shadel 04-01-2004 08:04 PM
Good Flying!
