RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   45 Throttle barrel (https://www.rcuniverse.com/forum/ys-engines-support-197/192631-45-throttle-barrel.html)
mrc100 07-11-2002 11:31 AM
45 Throttle barrel
From reading a previous post I understand the throttle barrel on the YS45 was changed a few years back. I have had a 45 for several years and was wondering how I can tell which barrel is in my 45? I also have a ultra thrust which I couldn't get to work very well, so I gave up. I may have just been using to large of diameter prop.
Mike
Dave Shadel 07-11-2002 12:14 PM
45 Throttle barrel
The metering slot is different. This goes bock to the very early 45's which is about 15 years now. I doubt yours is this old.
Dave
OldRookie 07-11-2002 01:04 PM
YS/Ultrathrust
I was the one who posted the YS 45 post.
Mine would run on the Ultrathrust pipe, but it always had poor transition, and a very narrow power area.
You are right on the prop size. The only way the engine would work at all is to have the correct prop to let it come up on the pipe. When you finally get it to come on the pipe, it had awesome performance.
It was just too unreliable to use for what I needed it for. If you were racing full bore it would be good, but not very useful in a sport plane.
The YS 45 and the Ultrathrust pipe are both great products, but not when they are used together.
Greg
