YS 91 AC Trouble again?????
YS Deadsticks
For some reason today, even with a higher than normal trim idle setting (due to this concern) the engine quits on final, this would be after I suppose a reasonably long idle but a fast one. I am wondering if I should tweak the regulator (which way), the low end air bleed or main needle?? Need some expert advice! Thanks. |
| All times are GMT -8. The time now is 01:21 PM. |
