RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   110 Too Lean (https://www.rcuniverse.com/forum/ys-engines-support-197/2189995-110-too-lean.html)
PlaneCrazzy 09-20-2004 09:59 PM
110 Too Lean
Dave,
Running a 15x8 prop with 30% Cool Power. Engine idles, when I apply throttle she bogs down running too lean. High end needle and regulator have no effect. I took apart regulator all clear. I pulled off fuel line, plenty of fuel and pressure. What are your thoughts ??
Chris
Dave Shadel 09-21-2004 06:32 PM
RE: 110 Too Lean
Did you put the regulator back on correctly? The bump on the casting goes forward.
Let me know.
PlaneCrazzy 09-21-2004 06:39 PM
RE: 110 Too Lean
Yes the regulator was put gack with the bump facing foward
Dave Shadel 09-22-2004 09:48 AM
RE: 110 Too Lean
If it bogs in the mid range and the regulator adjustment and HS needle have no effect, something is plugged in the carb body/HS needle. Pull the NV body and carb barrel and check for dirt.
PlaneCrazzy 09-25-2004 06:26 PM
RE: 110 Too Lean
Dave,
I took apart needle valve and carb assembly. Did not physically see anything. I blew out with compressed air
from the regulator hole back. I will check it this week and let you know if it had any effect
Chris
Dave Shadel 09-25-2004 06:53 PM
RE: 110 Too Lean
If it doesn't help, call Richard at service. He will be able to help.
775-782-4562
