YS
In disassemblying my YS110 I noticed that the wrist pin is a very tight fit in the piston and conrod. Is this normal?
RE: YS
Normally they are not that tight. Why did you take it apart?
RE: YS
Hi Dave,
Thanks for your fast response! I took the engine apart because after a recent flight, I found that the engine felt rough, felt like metal grinding, when I hand turn the prop. so I wanted to check what the cause was. I suspect it may be the bearing, but I only had no more than 20 flights and it has been running rich during this whole period and it had been running beautifully. I also gathered from the Ys spare parts list that the cylinder head and liner comes together as one part. Is that correct? Thanks again for your advice. mck |
RE: YS
The cylinder and liner are 1 piece, unlike the 2 piece version of the early 91.
RE: YS
Hi Dave,
Thank you for help, very much appreciated! |
RE: YS
Good flying!
| All times are GMT -8. The time now is 11:23 AM. |
