YS low speed needle valve position?
Dave,
I am getting ready to break-in my 110. Will be using Powermaster 20/20. I have it mounted on my 68" Yak for break-in/flying. Will run a few tanks thru before flying. I have set the High Speed Needle @ 2 turns out from fully closed (two turns counter-clockwise). How far out from fully closed should I set the Low Speed Needle to start with? Thanks. Michael |
RE: YS low speed needle valve position?
1.5 turns.
Go to www.ysperformance.com and follow the running instructions. This should get you started in the right direction. Let me know if you have any questions.. |
Thanks Dave.
You're welcome.
