RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   Need some help Dave (https://www.rcuniverse.com/forum/ys-engines-support-197/295431-need-some-help-dave.html)
AV8TOR 09-30-2002 11:28 PM
Need some help Dave
Dave I am having problems with a new YS91. So far it has about 18 ounces through it in a rich break-in (2 turns out) ground run. I have a APC 15x8 prop using Powermaster 20/20 fuel with an OS type F plug. I am using a 14-ounce tank that the lines come out on the carb centerline. The engine is horizontally mounted with the muffler side down. I have a two-tee fuel setup both behind the fuel filters and check valve. The check valve is setup so you can blow back into the tank. The check valve is on the vent side and I am using a filter on each line going to the engine. The problem is fuel is leaking out of the carb when you shut it down at a rate of 2-3 drops a second until I relieve the vent pressure. The regulator is set with the brass screw flush with the bottom of the casting. Any ideas? OK here is where it gets weird. My wife’s uncle is also trying to break-in a YS91 also and he is having the same problem. These are brand new engines. He is using a 3-line set-up with the one plugged. Hard to believe that two engines have a problem so I guess it is in our set-up but I can’t see what is wrong.
Dave Shadel 10-01-2002 01:19 AM
Need some help Dave
The plungers are leaking! Either you have debris in the regulator which is holding the plunger open or you need to go in on the regulator screw. Go in 1/2 turn and see if the leak stops
Dave
AV8TOR 10-01-2002 01:54 AM
Need some help Dave
Dave
Thanks Dave. Should I take the regulator off and check for debris before I turn in the reg screw? Please go over the proper way to clean the plungers.
Dave Shadel 10-01-2002 01:07 PM
Need some help Dave
Just take the regulators apart completely and clean them with fuel. Make sure you get them back together correctly.
