YS 120 Problem
I've got a YS 120 that doesn't have a lot of time on it and has been the best running engine I have owned. I have always run it a little rich so that it would stay well lubricated. The other day it decided to give me some problems. I took off and after getting airborne it started to sputter and then it died. I landed "safely". I have tried to tune it but the problems I am having are that when I remove the glow driver it starts to act up. When running without the glow driver attached at high throttle it just dies for no apparent reason. When it does this the prop comes loose. Since it appears to run fine while the glow driver is attached then I would assume that it is running too rich but I have adjusted the high speed needle valve throughout the spectrum. It appears to run best when the needle valve is about half of turn out from all the way in which means I am having to run it lean which sounds like it is getting too much fuel. I have replaced the glow plug twice with no luck. Do you think there may be a problem with the fuel regulator? Better yet, what might be causing this problem? Any help would be greatly appreciated.
RE: YS 120 Problem
There are a number of problems with your engine.
The drive washer face is probably worn almost smooth if it spits the prop. The NVA is close to being worn out at 1/2 turn from closed and may need replacing. The running problem suggests and engine worn enough that it will not keep the plug lit at idle. Hard to say what else may be wrong without seeing the engine. |
RE: YS 120 Problem
I kind of figured it would be difficult to troubleshoot without hands on. Too many possibilities. I will box it up and send it in for repair.
Thanks! Splitess |
RE: YS 120 Problem
OK, thank you.
| All times are GMT -8. The time now is 12:07 PM. |
