91 ac props for pattern
I AM FLYING A WORLD MODELS TAI JI 60 RUNNING A HATORI FLEX HEADER PIPE INTO A HATORI 60 PIPE FUEL IS 15% MACH 7 FULL SYN. PLANE IS ABOUT 8 1/4 LB DRY GIVE OR TAKE 1/4 LB FOR CHEAP SCALE
I STARTED OUT WITH A 14X10 GETTING ABOUT 8300-8400 RPMS THEN WENT TO 13X10 9300-9400 RPMS I AM NOT GETTING THE VERTICAL THAT I WOULD LIKE STRAIGHT AND LEVEL IS GOOD LITTLE FAST THOUGH WHAT PROP WOULD GIVE MORE VERT PULL AND CONSTANT SPEED THROUGH INTIRE PATTERN WITHOUT OVER REV. THE MOTOR THANKS,GARY |
RE: 91 ac props for pattern
15x8 or 16x4 if you have the clearance.
Lose the 15% and put some real fuel in it. The YS engines thrive on NITRO, Cool Power 30% heli fuel is ideal. Try it! |
THANK YOU DAVE !
GARY |
Good Flying!
Dave, with this amount of nitro, i.e 30%, how much oil content would you suggest?
Thanks and regards Winrich |
Minimum 20%. The Coolpower 30 heli fuel contains about 23 or 24% low viscosity oil, I believe, and this fuel works very well in a YS.
| All times are GMT -8. The time now is 09:03 AM. |
