YS 45 FS
Hi Dave
Regarding my YS 45 FS 1. What are the symptoms of broken or worn bearings? 2. When do you recomend replacing the bearings if at all ( my YS has approx 70 hours )? Thanks in advance Brian |
RE: YS 45 FS
Rough when turning the crank. Noisy.
70 hours is a lot, but rust is usually the problem, not worn out from use. |
| All times are GMT -8. The time now is 09:03 PM. |
