Loss of compression
Dave, I have a 2 yr old YS 110 with very little run time on it. Last winter, shortly after taking off the muffler fell off and I dead sticked it in. I recently tried to use it (with a new Muffler) and it seems to have very little compression (You can feel a little, but I can easily spin the prop with one finger)
Anything I should check, or should I just send it in? |
RE: Loss of compression
Valves stuck, rings stuck? Pull the valve cover off, and make sure the valves move when turning the prop. Then, I would fill the tank, REMOVE THE GLOW PLUG and spin it up with the starter for a couple minutes. Be sure to do this at full throttle.
Put the plug back in and proceed as in a normal start up at low throttle. Bet the compression comes back. |
Sorry, I should have mentioned that the valves worked fine and the rocker arms had proper clearance.
I'll try your suggestion and report back. Thanks |
Let me know, thanks.
| All times are GMT -8. The time now is 03:06 AM. |
