RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   140l (https://www.rcuniverse.com/forum/ys-engines-support-197/4583420-140l.html)
wingster 08-04-2006 02:43 PM
140l
Dave
I have a 140L that I am having a proplem with. I am running an APC 16x10 prop at about 8500 Rpm. The needle valve is about 2 1/2 turns out and the regulator 1 turn below flush. If the regulator is near flush the transition is much too rich. Usually I can't get it too run rich at the top end even if I about it to 3 turns or more, although the engine will sometimes alternate between really reving up and running slightly rich after running at lower throttle for a while. The main needle valve is very insensitive. It tends to quit in the air If run at about 1/3rd throttle for a few seconds. It idles well but often changes idle speed by the end of the flight.
I changed the regulator plunger,diaphram, gasket - no change.
The tank holds good pressure.
I checked the valve settings.
When warm there is compression, but not great.
I am running S&W 30% low viscosity blend.
Dave Shadel 08-04-2006 07:37 PM
RE: 140l
It may be an early 140L without a gas ported piston. It certainly sounds like it could be. Pull the head and see if there are notches or holes in the piston crown.
wingster 08-04-2006 09:32 PM
RE: 140l
Yes, there are 4 holes.
Dave Shadel 08-05-2006 08:05 AM
RE: 140l
OK, then it needs to make a trip to service. The address is on the webpage.
Bipe10300 08-13-2006 10:35 PM
RE: 140l
1 Attachment(s)
Dave seems I have an Early L With the Same Symptoms, I have sent it back. But Still Consumes Twice the Fuel as My Later L. And It has Eaten up another Cam follower. When I sent it back said There was No Problems.
wingster 08-14-2006 05:19 AM
RE: 140l
Dave
Sorry to take a while to get back to you.
I will send it in.
Dave Shadel 08-14-2006 10:08 AM
RE: 140l
Bipe 10300, call Richard at service, 775-782-4562.
Good Luck!
Bipe10300 08-14-2006 10:16 AM
RE: 140l
I will Call Richard. Hope Good Luck! Does'nt Mean Anything.......LOL
