RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   H (https://www.rcuniverse.com/forum/ys-engines-support-197/5480703-h.html)
wild330 02-26-2007 09:10 PM
H
Hi Troy,
I have been using NMP exhaust on my 160 engines, the truth is that I am tired of changing the hatori 821 o`ring . They last no more than 6 galons of fuel.
Do you have any experience of this combo with the Central Hobbies viton o`ring replacement?
I didn`t buy the hatori header because I saw Marcelo Colombo hatori`s header coming loose almost every 2 flights, any reports upon these combos? Any solution for these problem?
Which combo do you prefere?
I live in Chile , and our experience with the 160 is very poor.
Best regards,
Patricio.
Troy Newman 02-28-2007 12:05 AM
RE: H
6 gallons seems a bit low...I have run this a bunch and usually change the o-ring about 75-100 flights. The Central Hobby Replacement O-ring is a different size than the hatori. The NMP header is 5/8" and the Hatori is 15mm. So the O-ring size is changed to fit the NMP header. You might have better luck. If you assume about 8 flights per gallon then you should be getting 8-9 gallons per o-ring. If you are not perhaps some better cooling may help.
Troy Newman
Team YS Performance
wild330 02-28-2007 12:40 AM
RE: H
Patricio.
