pressure pump fuel
Hi guys
have someone notice about the standard pressure there is betweene the outlet of fuel pump and inlet of carburetor in the YS160DZ. How many psi about. This information help me to start condition for set the screw of pressure pump fuel. Regards Alberto |
RE: pressure pump fuel
Hi Alberto,
I have found that the fuel pump pressure can range from about 7 psi to well over 30 psi. I would not be concerned about the pressure for tuning purposes, in fact it makes no difference what pressure your pump is putting out as long as it is pumping and not allowing air bubbles to enter the fuel line. Set the inital setting of the regulator flush with the body and needle valve about 2.5 to 3 turns out. Team Crossman |
The starting point for the Dingo pump is screw flush with the housing.
Troy Newman Team YS |
| All times are GMT -8. The time now is 08:40 AM. |
