RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   YS 63 valve adjustment (https://www.rcuniverse.com/forum/ys-engines-support-197/6498269-ys-63-valve-adjustment.html)
bbagle1 10-16-2007 01:50 PM
Could someone please explain to me the proper way to adjust the valves on a YS 63s. I have run the engine for about an hour now and love it so much I dont wanna screw anything up. Any tips would be much appreciated. I already bought the feeler gauge, is .002" the proper gap or is that too large or too small?
Troy Newman 10-16-2007 03:32 PM
RE: YS 63 valve adjustment
1 Attachment(s)
valves.....well there are a couple of ways to do it. If the engine is fairly new then about every 2-3 gallons you should check them and set them.
The clearances you be between about 0.04mm and 0.1mm or to convert to inches its 0.0015" and 0.004" The 1.5 thousands is tough to measure even 1 thousandth is tough.
You can buy a feeler gauge at the Auto Parts start. Its needs to go down to a 0.001" These are cheap about $2 or so.
I will work on a picture and diagram to show you what to do. There are a couple of methods, but using the feeler guage is the easiest for a new guy to use.
I do it will my calibrated finger but this is not good for somebody that doesn't know for sure whats going on. The idea is there has to be a gap....this ensures the valve does close. If it stays open because there is no gap then the piston could hit the valve or the valve stays open a little and doesn't seal.
The idea on these engines is to make the gap about as small as possible and still have a gap.
Its an easy process but I need to work on some diagram and photos to to show you what to do.
Another tool kit is good to get costs a little much for what it is...but I use it...
OS Part#72200060
I looked at the photo and it didn't show the little screw driver, but my kit I bought many years ago had the little screw driver in it....
I'll work on something this afternoon and get back to you on it.
Troy Newman
Team YS
Troy Newman 10-16-2007 07:36 PM
1 Attachment(s)
Ok here we go simple and concise as I can make it.
Let us talk about the valve adjustment. Usually when these gaps get too big it doesn't affect anything other than top end power. Idle, transition and so on are not affected. Just the Max power output. Yes if the gaps get extreme then it can affect lots of things but anything from the desired 0.002" to about 0.010" will not affect idle or transition. Only top end.
Turn the prop on the engine to TDC. If you bring it up against compression and slowly turn it about 90degs the prop shaft will sit in a notch like position. It won't be up against compression and it will be only about 1/2 way through the compression area. This is where the crankshaft must be to adjust the valve clearances. If in doubt about what is going on watch the tappets move as you turn the prop shaft. This will show the tappets moving up and down as they open and close the valves. The valve must be close meaning these is some gap between the tapped and the valve stem when you are adjusting these clearances.
Look at the drawing below. This drawing shows the tappet, the valve, and the pushrod. The adjustment screw, and the locking nut.
To adjust the gap or the tappet clearance you loosen the locking nut, and dial the adjusting screw.
Couple of tricks. First some of the YS engines have a slotted adjusting screw for a small jeweler type straight blade. And some of them have a small allen or socket head set screw style.
Use the allen wrench or the slot in the screw head as an indexing mark. The adjustments here are very small.
Place the little wrench on the locking nut. Then place the screw drive in the slot. Loosen the locking nut without turning the adjusting screw. This is tough...that is why I say look at the slot as the index. Inmost cases the locking nut needs only 1/2 turn or less to give the required adjustment.
Once the locking nut is loose. Twist the adjusting screw to get your desired gap. The gap can be set using the feeler gauge or some shim stock that is 2 thousandths of an inch. 0.002" This is a trial and error adjust the screw and check the gap with the guage material. The gap should be be " snug on the 0.002" strip, but it should not be tough to insert between the tappet and the valve.
Once the screw is adjusted properly carefully tighten the locking nut. The adjusting screw will want to turn tighter with the locking nut...but you need to hold it in place at the right spot while tightening the locking nut. This is why you use the slot in the screw or the "L" of the allen wrench as the indexing mark.
The locking nut doesn't get torqued down like a Nascar tire lug nut. Its just tight...Don't over tighten or you will break the adjusting screw. I have done it...It suck...Easy to repair and replace the screw but it sucks.
So tighten the locking nut. Then use your gauge again and check the gap. If the 0.002" gauge is a little tight in the gap that is good....then wiggle the tappet and look at the gap with your eye, or feel the little click click back and forth as you wiggle the tappet back and forth. If you have a little click click or can see a gap the Valve is closed. This is GOOD and what you want.
This is the setting for max performance. To be on the safe side the 0.002" gap is fine. You might be down 100rpm, but the valve will no doubt be closed...this is what you want.
Caution it is very easy for the adjusting screw to put pressure on the valve and cause it to open. So you have to have a gap...that gap should be small. The instructions say 0.002" I try to set mine a little tighter than this with the above instructions.
If you use the OS kit...there are two little metal strips as seen in the photo. The thicker one is 0.1mm and the thinner one is 0.04mm So your setting should fall between these two for thickness.
Basically you make it tight enough that the thicker one will not slide through. And the Thinner one does slide through it.
these are the basics. Its and easy 5 min task.
Clean the valve cover gasket and engine head with denatured alcohol and re-install. If you are not careful when taking it apart you can tear the gasket. If the gasket sticks to one side or the other this is fine just leave it there. Valve cover screws again are not torqued tight...they are just tight...A little beyond snug.
party pooper 10-16-2007 09:42 PM
Troy,
Your post is excellent, so don't take my quesition the wrong way. Could you review in a different manner how to postion the engine in the correct location for valve adjustment. I hear stories of some guys being off on the engine rotation 180 deg's and I forget how to assure myself that I'm on the correct TDC. Would the safest thing to do here is remove the glow plug - watch the piston go to the top - and make sure both the intake and exhaust rockers are loose or is there a better method?
Blair
Troy Newman 10-16-2007 10:12 PM
keep the glow plug in it. Put a prop on it....have the prop at a "horizontal" location. Meaning the prop is horizontal and the cylinder head is vertical. Turn the prop slowly against compression...if you turn it so the prop is about vertical up and down and in the middle of compression it will kind of notch into place and sit there....It will have compression to turn backward and compression to turn forward. It makes a kind of notched into place feel. This is the point at which the valves are closed and the pushrods are at their lowest point...
You can also watch the tappets.....You want the tappets to be "at rest" when you make your adjustments....If they are being pushed down onto the valve stem you can't set them.
Try the compression this.....Looking into the glow plug hole can be tough...if the engine has time on it the oil can look a little glassy in there and you can't see whats going on.
You could stick a probe in there like a small wood dowel....but why...with the glow plug in it...you can find the compression...bring the prop up against compression and then go slowly a little further and it will notch into place...leave the crank in this spot and set both valves.
As soon as you turn past this spot the exhaust valve will start to open...
Its easy to see with the engine in hand.
Troy Newman
Team YS
