RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   YS120 regulator? (https://www.rcuniverse.com/forum/ys-engines-support-197/682703-ys120-regulator.html)
Got Smoke 04-09-2003 02:09 PM
YS120 regulator?
ok, i replaced the regulator spring, diaphram, plunger, and gasket. fuel tank, fuel lines, and fuel valves. i still have a leaky carb when engines not running, and when i release pressure it's more of a gurgle pss, than the PPPSSSSSSSS that i used to get.
heres my original post to clear things up.
http://www.rcuniverse.com/showthread...28&forumid=156]
can773 04-09-2003 02:10 PM
YS120 regulator?
Did you clean or replace the check valve?
Got Smoke 04-09-2003 02:16 PM
YS120 regulator?
i bought this engine used. i have no manual. please direct my to where the check valve is, or a site where i could get a manual .thanks
Dave Shadel 04-09-2003 02:44 PM
YS120 regulator?
Call YS Parts at 775-782-4562. They can sell you a check valve and get you a manual. If you're trying to run it without a check valve, it won't work.
