RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   New FZ63S..problems (https://www.rcuniverse.com/forum/ys-engines-support-197/7130967-new-fz63s-problems.html)
cooperd 02-24-2008 06:57 PM
New FZ63S..problems
After a quick break-in run on a test stand, I installed this engine on an airplane and flew it a total of about 20 minutes during 2 flights. The engine quit both times in flight. It seemed to be running fine when I elected to fly with it. I could tell it was a bit rich and I figured it had loaded up from running at reduced power and that is why it quit. I put the engine back on the stand and after some minor adjustments it seemed to run fine. Nice idle at 2500, but would go no lower no matter what I did. The next session on the test stand the engine acted totally different! Made no adjustments initially. Would not run much lower than 4500 RPM, surged at all throttle settings except wide open.
I have tried everything suggested on this forum, but am unable to get this engine to stop surging and to idle properly.
I used Cool Power heli fuel 30%(orange color)
OS F glo, although I have tried a Saito, and a Hanger 9 4 Stroke plug. OS worked best.
I have tried setting the regulator to flush and on down to as much as one turn below flush....in increments.
Main needle open 2 to 2.5 turns
Idle(low speed) screw 1 to 2 turns and everything in between.
With the throttle plate all but closed...only a sliver of an opening, the engine will run at 4500 to 4800 RPM for 30 to 40 seconds, then abruptly it will drop to 3000-3200, but the engine will die. With so little throttle opening is it getting air from a leak somewhere ??
The fuel tank is holding pressure fine. It will store air pressure 5 minutes after the engine has stopped.
The line from the regulator to the carb will produce a stream of air bubbles when I attempt to throttle back to 4000 and below. NO AIR BUBBLES IN ANY OTHER LINES!
This is my first YS engine, but I have three Saito 4 strokes and 5 2 strokes of varous makes , and 4 diesel engines and I have NEVER encountered this much grief with a new engine.
I have run an entire gallon of Cool Power heli fuel through this engine while trying to get it to run.
I must be missing something here!
cooperd 02-24-2008 11:05 PM
RE: New FZ63S..problems
May have solved my own problem here. Realzing that for the engine to run at such high RPM with the throttle plate virtually closed, I decided to take some things apart. I pulled the throttle barrel out and found the throttle barrel seal ring was broken. So will have to wait for a new one to know for sure.
Troy Newman 02-25-2008 11:36 AM
That would do it...
Also dialing the regulator screw in is leaning then engine out.
If it surging its already lean.
Always on YS engines surging is lean.
special Note...
The throttle barrel seal has a flange on it. This flange goes toward the engine when on the barrel. You can't install the barrel from the needle valve side, as the flange will be damaged. You have to insert the barrel from the exhaust side and push it all the way through...This will keep from damaging the new seal.
Troy Newman
Team YS
cooperd 02-25-2008 06:18 PM
Ok thanks! When I get the seal I'll try again. I never did try the regulator screw turned above being flush, but I spent a lot of time with it at the flush position...always surging. I'm at 4000'msl in AZ with outside temps above 70 degrees. So I would expect I would have to lean from the normal settings, however, as you say the surging indicates too lean, so hopefully the seal was the problem.....unless I tore it getting it out. Time will tell.
cooperd 03-03-2008 05:44 PM
Well that didn't go well! After waiting a week for the throttle barrel seal, all that arrived from my order from Central Hobbies was the O-Ring Kit. The seal is on back order....no indication how long. No luck at Hobby Barn where I bought the engine. Their spare parts list is meager at best.
Ah! Just called YS Parts and Support! They had the part and are sending it right out, even giving me a break on the shipping cost. Life is good again!
Troy Newman 03-03-2008 06:11 PM
I think a parts order is coming with the engine order this week or next.
Richard tends to keep a small stockpile of little things around for repairs and such.
Troy Newman
Team YS
