RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   YS 45FS problems (https://www.rcuniverse.com/forum/ys-engines-support-197/903341-ys-45fs-problems.html)
Aggravator 06-27-2003 04:03 PM
YS 45FS problems
I'm using 20/20 fuel, KB RC plug with idler bar, 10x6 APC, and Macs header and pipe. The engine starts and winds up to just over 15000 rpm, so the pipe length must be close. After 5-10 seconds (without adjusting needle), it starts to stutter and lose power, then fuel starts spitting from the carb until it eventually dies. After allowing it to cool off a few minutes, it starts easily, but the same symptoms repeat again. What am I doing wrong?
Doug
Dave Shadel 06-27-2003 06:18 PM
YS 45FS problems
The pipe is effecting the operation of the regulator. Take it off and try running it. Let me know what happens.
Aggravator 06-29-2003 04:58 PM
still flooding
Took the pipe off and ran straight header pipe. Got a little over 14K rpm. Same results, ran for a 20-30 seconds or so before flooding. In flight, it would run an extra minute at full throttle, but would die when throttle was backed out. I think I noticed a fuel leak from the front main bearing, so maybe it's sucking air there. Might need a rebuild.
Doug
Dave Shadel 06-30-2003 12:53 PM
YS 45FS problems
Sounds like it needs some help. Maybe you should send it in for a checkup.
YS Service
1295 Industrial Court
Gardnerville,
NV 89410
775-782-4562
