ys 120 piston
Hello
I have a ys120FZ engine that ran perfectly on my G-trick 2 weeks ago I replaced the prop with a new one but so how I installed a wrong prop. Flew the plane for 3 rounds before the connecting rod broke and damaged the piston,valves. Lucky or unlucky ,a friend of mine crashed his airplane a few weeks ago and damaged his ys 120. Some parts were saved. He gave me the parts and I replace the broken one on mine. The replacement piston came with 4 pin hole size on top , my broken one did not have this. Anyway I assembled the engine but some how there is no compression in the engine. Except for the pin hole checked every thing worked fine. Started the engine no problem ( just no compression ) Quest? Are the ys120 piston different on other models or are they interchangeable Or do I have to get a piston without the pin holes? I might send it to the YS for service. Thanks C LIm |
ys 120 piston
Please send it so it can be repaired properly.
YS Service 1295 Industrial Court Gardnerville, NV 89410 Phone 775-782-4562 Thank You |
send engine
Thanks for the quick reply
Mr Shadel I'll do that. A friend of mine has a ys140L that also need service so we'll split the shipping cost. Thanks again. C. L im |
| All times are GMT -8. The time now is 02:08 AM. |
