ZDZ & RCS Support Direct support from Mike Dooley of RC Showcase for all your ZDZ and RCS Engine questions.
Rcs140
Old 07-22-2002, 08:42 PM
BAS
My Feedback: (28)
Default Rcs140
I just orederd the rcs 140 and i am putting on a Creek Hobbies staudacher which is suppose to wieigh around 10 and 1/2 to 11 lbs i hope this motor will give me good vertical any comments would be appreciated. I have heard the 140 really is a nice motor and will turn some high rpms . Also could anyone tell me about the ignition on the 140 does it take a regular switch type hookup like a heavy duty jr or Hitec swith also what kind of plug for switch hookup does it have???? can i use a 6 volt batt for this setup or does it have to be 4.8 thanks Bruce
Old 07-24-2002, 05:00 PM
Mike Dooley/RCS
Default Rcs140
Hi Bruce, The RCS 140 Ignition system cames with its own special connector and terminals to adapt to your ignition switch harness assembly. A good 4.8V pack of at least 1200mah is sufficient. Please be sure to crimp and solder the connections. You should have unlimited performance in an 11lb airframe. Please feel free to contact us with any further questions.
Mike Dooley
RC Showcase
301-374-2197
Old 08-13-2002, 08:01 PM
Sky Viper
Default Rcs140
Mike,
Would you please clearify.
Does this mean 11lb frame + electronics and engine? Or does it mean an "All Up" "Ready to fly" weight?
Old 08-13-2002, 08:19 PM
Mike Dooley/RCS
Default Rcs140
Full aerobatic performance at an all up weight of 11lbs or less.
Mike Dooley
RC Showcase
