RCU Forums
-   ZDZ & RCS Support (https://www.rcuniverse.com/forum/zdz-rcs-support-204/)
-   -   Drill Jig Problem (https://www.rcuniverse.com/forum/zdz-rcs-support-204/3865406-drill-jig-problem.html)
mrbigg 02-03-2006 09:38 PM
Drill Jig Problem
I just received the drill jig I orderd, and it seems the holes don't line up with the front hub. It lines up closest with the inner set of holes but is off a little bit. These sets of holes are too small for the bolts also. My engine is a ZDZ 120.
Mike Dooley/RCS 02-04-2006 02:38 PM
RE: Drill Jig Problem
ZDZ has matched to hub bolt spacing of 3W and DA, which is 34mm for over 2 years now. If you have an older ZDZ 120 or 160, the bolt spacing will be 31mm.
mrbigg 02-04-2006 04:06 PM
Do you have the right jig or am I on my own?
