Official Mini-T Thread
#2951
RE: Official Mini-T Thread
I might get the 12mm adapters so I can use the same tires the Detta ST uses so I don't have to buy twice as many tires since I plan to get my Detta ST running after my Mini-Slider conversion is done.
#2952
CT
evan t, I still use both of my mini-t's here and there but not much, I really want to sell my brushless mini-t but I know im not going to get what I want for it on ebay, I want 200 but thats rare to get, I want to buy another heli
#2953
MI
ORIGINAL: HeliStyle
#2954
CT
it has castle creations 6800kv motor and esc
proline dirt hawg tires mounted on chrome rims
losi ball bearings
gpm aluminum front suspension arms
gpm aluminum rear suspension arms
racers edge front and rear aluminum pivot blocks
robinsion racing 13 tooth aluminum pinon
racers edge aluminum front knuckles
losi oil filled shocks
integy aluminum servo hold down
hitech hs55 steering servo
mip ball diff
losi cvds
kyosho 75mzh radio and reciever
losi ball bearings
mip ball diff
losi cvds
#2955
MI
wow, sounds like a nice mini. I would try to list it on ebay. If you put a reserve on it, it will not go any lower than you want. 200 does not sound too bad. if it does not sell, you are only out a couple of dollars on the listing cost.
#2956
TX
heli go to your lhs and see if they put sell stuff on consignment thats how i sell all of my stuff lol and if they dont then try selling on ebay i guess good luck
#2957
PA
My LHS has a case, they put a sign, upgrades, and a price, theres new stuff in there all the time for mad good prices, i was tempted on a race ready revo for $300 never used, went back the next day, gone ...
#2962
I finlly recieved my upgrades for my mini baja.
1 Set of GPM Shocks
1 # racing ball diff
1 set of GPM Turnbuckles
everything was going together great until I got to the last turnbuckle. As I was unscrewing the stock ball to replace it, wouldnt you know it the darn front knuckle arm broke. So now I have to put in another order and wait. I was debating on whether I should get the aluminum version ar just stick with stock. Any feedback on this? Im not a big fan of aluminum but I would like to replace the flimsy parts with something better.
1 Set of GPM Shocks
#2963
MI
I ran with the same question on Friday. I fired my mini up and broke a rear knuckle with in 2 minutes. I had alum ones on it but put stock back on recently. The stock is what broke. I had sold the alum ones recently and was thinking the same as you, would the Alum be better. Dummy you sold them.....
I still think no. I would rather have to replace a knuckle than an arm, a pin, and or bulkhead because the knuckle would not give due to it being alum.
#2964
I would break knuckles less often then I would break my rear suspension mount. I guess it doesn't like 7 foot jumps and landing on the rear right tire almost sideways several times on asphalt. Does anyone know of a good shim set to get rid of some of the slop in the Mini-Ts suspension? I got my eBay account set up so I'll be buying more stuff for my Mini T/Slider in the next weeks.
#2965
I think I found what battery that I'm going to make/use for my Slider/Mini-T. It's going to use 6 2650 mah Duracell AA cells. Its heavy but the extra run time will be worth it.
#2968
ORIGINAL: Frozen72
#2970
you better go with lipo/a123.
I might try a123, still looking for more info on them, but heard a lot of good things except their weight.
#2972
NJ
I use Zippy 1300mah 2S Lipo's. I get 30 minute run times and they weight half the weight of the Nimh's. I also have some Zippy 800mah 2S Lipo's and they give me about 12 minute runs times. Good stuff. Ordered them from hobbycity. REALLY CHEAP TOO but GREAT quality.
#2973
Will A123's give you the same or close to the power and runtimes of a lipo? Do they need to be balanced? I dont want to buy any more nihm batteries since there are comparably priced alternatives now but I want to know if I go with either lipo/a123 what additional things I would need.
#2974
a123 1100 about 40gr/cell
2s 95 gr
3s 130gr
4s 190gr
the 2300 about 70gr/cell
2s 155gr
3s 230gr
4s 310gr
no problem with run time, they fully charge in 10 minutes
get 2 pack you can run all day long.
probably I'm going with the 3s 2300, any suggestions?
2s 95 gr
3s 130gr
4s 190gr
2s 155gr
3s 230gr
4s 310gr
