Team Losi Mini LST
#226
RE: Team Losi Mini LST
ORIGINAL: Sao
And you cannot spell GrammAr
Unless thats some US way of spelling it
Oh be nice! Don't get me started on your grammer or spelling. :P Was funny!
You couldn't even spell "SENTENCE" lmao :P good fun!
#227
NJ
SAO,
Don't you have a mission to complete? Since you are the only one to have touched one and know of a LHS that had one. The CAPT gave you strict orders to aquire that MLST (by any means possible. IE steal it, Buy it, borrow it) and bring it back to headquarters for further inspection!!! No get to it soldier!!!
#228
NJ
yea sry for the grammar errors it was late and i just got back from running a couple miles and yea i get wut u mean the mini lst is the mini that has everything ppl have wanted and two bags of chips
#229
ORIGINAL: houseplant
#232
ORIGINAL: captanabolic
SAO,
SAO,
Mission postponed due to logistics failure
Will try to get to the target this weekend
I'll try to get them to open up the diffs so I can have a look at the gears
Pictures to follow
Sao Out
ORIGINAL: mayhem maniac
except me. i still correct people
Except me, I still correct people.
#233
Anyone know whats the motor limit for the esc on the mini lst? I was thinking about putting a grupner 400, in there.
BTW someone told me that a 370 motor is a 400 sized motor is this true?
close enough. i think im going to go straight for the brushed 540 motor and i have a correspondant checking out the chances of this working at the upcoming iHobby expo.
#236
ORIGINAL: nedMX
#238
FL
have you guys wondered wat if u wanna upgrad it to two berushless motors, how would u take advanteage of the dual motor mount with 2 brushless and 1 battery?
#240
BC, CANADA
Why? Just because Castle Creations said so? Theres no reason it can't be done. Electric airplane guys do it all the time so it is possible to run 2 motors on one esc. As well theres no reason why you couldn't run 2 motors with 2 escs. Either from one battery or separately.
The real question is will you have to? I think not...
There are plenty of choices beyond Mamba's. If they don't make a bl large enough there are others that do. I am sure it won't be long before Mamba steps up to the plate as well.
#241
The reasin you cant do it with two brushless in the L:ST is because they are both turning the same gear, if one motor is even 5kv out then the lower kv motor will burn out. In a plane two motors on one esc driving two props is not a problem.
#242
BC, CANADA
If you say so. But then how do you explain the many dual and even triple brushless trucks out of there. They shouldn't work either and yet they do. I personally know people that have done so with no problems. These are multi escs in these trucks. I only know of airplane guys pushing dual motors (as far as I know) per esc but the same rules should apply. If it works for them it should for this if done properly. This is proven fact that it works and works great for many many people.
I would think that the same rules would apply that apply to dual nitro trucks. They work and work well. (I personally owned a Twin Titan) The motors have no choice but to equal out. One may be working a bit harder then the other to do so but but so what. Its close enough and as long as they aren't over heating your not doing any damage to them.
#243
ORIGINAL: outcastrc
OK SOMEONE BUY 2 MAMBA 8000 for the price of $250 then run 2 batteries? or 1 battery and a really short run time.. its just not practical. get a 540 conversion and all is settled
#244
Actualy,the run time with stock motors id 13 minutes.And you can fit a 3 cell lipo in there whitch would make it have extrmely long run times,and lipos for minis are extremely cheap!
#245
ORIGINAL: rc rager
#246
Look here,you must not have any experience with mini lipos at all,becausethey are very powerful and hold a ton of run time.do you see those people at the races go without having to charge it more than once,and they have mambas?You could still get atleast 15 minute run times with 2 mambas and i 3 cell lipo.[>:]. I'm not sure about you but thats a pretty long run-time for me.And ive seen it done by a losi worker and i worked like a charm.
#247
ORIGINAL: rc rager
#250
YES...latest pics from ihobby expo...MLST hopups
http://www.*************.com/images/ev...expo%20096.jpg
http://www.*************.com/images/ev...expo%20095.jpg
http://www.*************.com/images/ev...expo%20122.jpg
please replace stars with the - rc - zone(spaces between dashes removed) it seems RCU is being childish but lets not get into the arguments.
heres the http://www.*************.com/images/ev...hobbyexpo2005/ whole lot for those who want other pictures. this is just a sample and there are another 500 photos still to be sorted and uploaded. once again, replace the start with the - rc - zone.
