deans plug
RI
RE: deans plug
There isnt much difference in deans. http://www2.towerhobbies.com/cgi-bin...&I=LXKX39&P=ML / http://www2.towerhobbies.com/cgi-bin...&I=LXDKA2&P=ML
RI
RE: deans plug
This is the better one for micros. http://www2.towerhobbies.com/cgi-bin...&I=LXDKA2&P=ML
ON, CANADA
RE: deans plug
Crimping has the least resistance, but not many people want to go out and spend 250 dollars on a good crimping tool. The best deans are deans ultra, you can get them pretty much anywhere.
RE: deans plug
Banned
NY
RE: deans plug
ORIGINAL: Mattdg67
Yes but you are going to have to unplug the battery at some point. So its just retarted to soilder it directly.
RI
RE: deans plug
ORIGINAL: pre98zetec
I think they mean solder the motor directly to the ESC.
ORIGINAL: Mattdg67
TX
RE: deans plug
the only reason to use anything other than a deans ultra is if you are an idiot or have a car smaller than 18th, such as a micro t. the deans ultra fit just fine in my 18t and like someone said, they have less resistance than an equal length piece of wire, this was tested in one of the magazines about a year ago. people normally dont argue about direct soldering motors, the argument is about whether or not it is more efficient to direct solder your battery, and deans plugs have proved that it is not. you can buy deans plugs at any decent hobby shop for about $3. best thing you can do to an rtr in my opinion.
RI
RE: deans plug
Unless you swap motors everyday I don't see why its retarded. All my motors are soldered directly to the ESC.
ORIGINAL: Mattdg67
Still thats retarted
ON, CANADA
RE: deans plug
ORIGINAL: joeyblaze
umm deans ultra plugs have less resistance than a pieace of 12g wire the same size including the soilder .. how can u get better then that
